Scrambler rebuild help please
Results 1 to 2 of 2
Thread: Scrambler rebuild help please
    Aug 2011
    North Idaho
    5
    I'm in the middle of rebuilding my 19?? Scrambler Model 1200. The serial number is 11214. Does anyone know how to determine what the year of manufacture is?
    Attachment 19053
    Also I've run into a problem with the clutch plate shaft bearings that need to be removed and replaced. There are two inside the shaft. I can get to the one closest to the face of the clutch plate but the one below it is too far in and too small to reach and remove with any tool I have. The shaft is closed at the other end so can't access it. Any ideas on how to get that bearing out without breaking something?
    Thanks for the help!
    Jun 2009
    Nrth West Minnesota
    14
    hi saw your post today. If its not too late we believe you have a 1200, same as us. Did alot of work and I have a parts book and some other stuff. My Scrambler is in my garage now cause of brake fluid and zerk replacements. let me know if you still are working on it. keith
