T-20 detent spring
Results 1 to 5 of 5
Thread: T-20 detent spring
    Feb 2020
    Southern IL
    5
    T-20 detent spring
    Can some one tell me the specs on the detent springs that go inside the shift collar? I seen a thread where someone used 3/16” D but the springs that are in the transmission now are 1/8” D. I’m asking because I don’t know which is right and I can’t seem to find much on this topic. I did get the length from max6x6 parts at 3.73”. Any help would be great! Thanks in advance.
    Fairbanks AK
    1,460
    I’ll pull one and measure it tonite. Going to try and find new source also
    Fairbanks AK
    1,460
    Spring measures.155” OD. 3.431” length of coils. 3.750” end to end at loops. .025 “ music wire. I’ve found several spring makers that will make custom springs. Prices look as if a purchase of 50 is only a few bucks more than 10. Idd be into splitting up an order if anyone else need 10. My stock is very low. Had to dig to find a good one.
    Feb 2020
    Southern IL
    5
    Thank you very much for the info. How can u tell it’s music wire?
    Fairbanks AK
    1,460
    It’s not stainless steel.
Tags for this Thread
