Belting for Tracks?
Results 1 to 7 of 7
Thread: Belting for Tracks?
    Mar 2021
    Atlantic Canada
    54
    Belting for Tracks?
    For those of you who have made your own tracks before - where did you find your belting for the tracks? I'm in the processes of making some chanel tracks, just figuring out how to get my bends and angles consistent, but in the mean time I haven't had any luck sourcing belting. Used 1/2 PVC conveyor belting would probably be a good choice, but I haven't had any luck there either.
    If anyone has any advice on belting material or sourcing, I'm all ears!
    2,668
    bennet..3 co.s are anchor rubber products , michigan industrial belting inc. and totally belting . com . check them out on the web . seem to be others also . johnboy va.
    Dec 2018
    Muskoka, Ontario
    95
    I got lucky and just happened across a discarded piece in the bush while I was buzzing around and it happened to be just enough to slice up for a 6 wheeler
    2,668
    yea ....there are also co.s selling used belting that you can cut to size you want . good luck , j boy
    Oct 2010
    Wasilla, AK
    923
    what’s your location?
    Mar 2021
    Atlantic Canada
    54
    Sorry for being late to reply to my own party, I ended up on call for the weekend.
    John - I took a look at those suppliers, I wasn't able to find any prices listed online but I'll shoot them a message. Being in Canada makes it a little harder because shipping belt can be very expensive!
    Facemelter - Reminds me of being young and finding certain "magazines" in the woods! That's some crazy good luck. I was hoping to find some old equipment with a long belt on it at a junk yard or similar, but nothing so far.
    Buzz - I'm in New Brunswick, Canada. I nearly reached out to you for a quote but didn't want to waste your time due to shipping expense and the conversion rate. If I ever end up with a newer machine with a little more tub clearance though, bushtracks will be my first choice for sure. If memory serves, you use to make chanel tracks for a time before you switched to you current tracks? I use to pop in here from time to time years before I ever made an account, I'm surprised at all the usernames that have remained consistent over the years.
    Oct 2010
    Wasilla, AK
    923
    Bennett,
    Any supplier of reinforced conveyor belting should be able to give you a quote. You can save some money by cutting to your preferred width yourself. For example 18” wide belting gives you (2) 4” wide pieces and (2) 5” wide pieces. But it depends on the widths they offer to see if it’s worth it.
