Can you fix an argo tire?
Results 1 to 7 of 7
Thread: Can you fix an argo tire?
    I have Rawhide III tires on my 04 conquest, I have a small leak on the side of the tire, Can I put a patch inside? I know the tire deflects a lot when playing in rocks, will it last ?
    Thanks
    Last edited by Mike; 09-23-2013 at 08:57 PM. Reason: moved thread from Argo forum to Tire forum
    5,055
    As long as the inside of the tire is good it can be patched, use a larger patch (boot) about 2x4 and it should last a long time.
    Jul 2009
    Cleveland,Oh.
    1,589
    consider using an inner tube if nothing else works.
    Oct 2012
    Winnipeg, MB
    88
    I've had great success with 4-5" radial patches on Rawhide III sidewalls.
    Make sure you do it correctly
    Here's a good video if you're not familiar with the process ATV Tire Repair Pt 1 - YouTube
    Aug 2011
    Carleton Place, ON
    52
    Here's a great 2 part video for tire repair, best of luck
    just realized it's the same video.
    Feb 2019
    Germany
    28
    Tubeless tire repair
    I Know its old, but here is my Argo tire repair Video:
    https://youtu.be/PJFTAGPkDsA
    Greetings from Germany
    Jens
