1992 Max 4 rebuild
Results 1 to 6 of 6
Thread: 1992 Max 4 rebuild
    Dec 2007
    amesbury.ma.
    227
    1992 Max 4 rebuild
    Hi all. So I'm doing a frame out rebuild brought about by some sprocket bolts that broke and worked there way out as they were spinning. Needless to say they chewed a few troughs in the bottom of the hull. I'm plastic welding the holes but can't remember what size rivets held the skid plates on. Does anyone know if they are specific waterproof rivets. Started this project a few years ago but got side tracked. Thanks for any help. Mike Duggan
    Dec 2007
    amesbury.ma.
    227
    Bump. Does anyone know what size rivets are used on the skid plate on a Max 4. Are they waterproof. Thanks Mike
    5,055
    3/16 by 1” maybe? Contact Max direct if no other replies.
    Dec 2007
    amesbury.ma.
    227
    Thanks for the info. Is there a rubber seal on it. I was assuming they were water proof.
    Fairbanks AK
    1,460
    The rivets are closed end liquid tight 3/16 “. I’ve seen a small rubber washer on some up on the sides of the tub. Bottom of skid plate is countersunk to keep heads covered. McMaster Carr is the only place I’ve been able to get them after RI was gone. I’m not sure of length but think 3/4” grip range was the longest available.
    Dec 2007
    amesbury.ma.
    227
    Thanks for the info. I'll be ordering soon.
