New battery problem
Results 1 to 5 of 5
Thread: New battery problem
    Cool New battery problem
    while hunting i used my winch after i got to my duck blind the argo wouldn?t restart. I got a jumper pack and jumped it and got home.i then bought a battery installed it and with the key off the gauge is flashing. with the key on nothing happens.i replaced all circuit breakers and jumped the key switch and still nothing happened.I made sure the ground from the battery to the case was tight and clean. I also unplugged the winch and nothing still Any ideas on what I should try next. thanks
    its a 2020 6x6 scout 700
    Texas
    2,172
    Check the battery is actually charged up to 12.2 volts at minimum. Check the connections again to make sure nothing got connected to the wrong terminal. Lastly check your engine oil as the low oil cutoff may have kicked in.
    A few months back I had a similar issue with my ZTR, and the oil was just low enough that the protection kicked in.
    oil looks full. all i did was replace a battery. i think something got burnt using a small jump box. thanks
    new Die Hard Battery was bad thanks
