Richard's thicker bands
Results 1 to 3 of 3
Thread: Richard's thicker bands
    Is there a trick to installing the U channels with Richards bands? I can barely get a thread or two started and there's no way the adjustment tool will fit under the bolt heads. Should I just get longer bolts?
    Thanks
    Fairbanks AK
    1,459
    Longer bolts just an additional 1/4” inch should do. I see different length at times from the factory.
    Thanks!
    That's what I ended up doing, 1/4" longer seemed to work perfect. Appears to have adjusted correctly from what I read on Richard's site and the Borg Warner manual.
