Center Gasket Dimensions and Diagram ( if it helps anyone )
Welcome to 6x6 World.
Hi All,
I got some new gaskets but they weren't in the greatest of condition and they seem pretty thin, so I was wondering if anyone ever cuts their own? To this extent, in case it helps anyone in the future, I measured the gasket up and it looks to be around this....
I'm seriously wondering if I would be better machining one out of copper sheet too... Or maybe copper would be too hard for aluminium, but I figure the dimensions might help someone else in a pinch who pulls theirs open and just wants to cut a gasket out of material.
I will qualify that I only measured it up, so I'm not 100% sure of the perfect dimensions, and there's a slot cut from the small holes to the edge of the gasket but this is what it seemed to be.
The outer size is 10"... The gasket should be about 1/32 smaller than 10"
The inner size is 8.5"... The gasket should be about 1/32 larger than 8.5"
The holes seem to be cut on a 9.5" diameter line.
Holes are 1/3"
Gasket thickness is 13 thou or around .32mm
Angles between holes are 30 degrees.
So if you have a compass and some gasket paper you should be able to make one.
