Attex or Hustler
Results 1 to 3 of 3
Thread: Attex or Hustler
    Jan 2010
    byesville oh.
    101
    Attex or Hustler
    Which one is the better 6x6 and what models have reverse just ones with the t-20 trans or are there others
    Jan 2008
    Vicksburg, Michigan
    3,508
    Are you comparing attex and hustlers?
    Hustlers are bigger. They are great machines to grab a few friends and go off exploring. Early models are fiberglass and then poly bodies which I believe to be stronger. And I have repaired them and they seem easier to repair then the abs body.
    Attexes are smaller and lighter. They are the sporty model ussually. The have a higher top speed. The can be great for trail riding and offroading too. Just not as beefy as a hustler would be. Early baker hill 6000 series machines didnt have reverse. A reverse tranny can be swapped in if you can locate one. Early up to '75 the machines where abs. Then '76 and later are poly body.
    Larry mentioned many great points. If I were you I'd get both because they're both excellent machines and they both have many strong attributes to them.
