Originally Posted by
trevorakm1
I added two fans to pull air from the engine compartment and to avoid the the battery issue I got a 3 position switch and wired the fans to it. so now I can start the argo and let it warm up at idle with the fans off when ready to drive turn switch to second position this turns brake fan on. I can then move switch to third position and this will add the fans I added for the heat previously mentioned. and turn them off when sitting at idle. may have confused the secon and third position fan associated to them. Got the switch from ebay also at the boating stores.
