Hi,
I have a problem periodically with my clutch in my 2003 Max II (23 hp Kohler). By times when I release the throttle the clutch remains engaged even though the engine is at an idle. The machine creeps forward and sometimes will stall. If I pull the sticks back and rev it a couple of times sometimes it will release. Also sometimes when the clutch is sticking and when I shut off you will hear it make a loud clunking sound as it releases. Upon restart after that clunking sound it is released. Everything looks good in there and revving it it appears to be working properly.
The belt I am using is a Gates I believe P/N 6314 and a cross for that is a Dayco HP3003. I am thinking perhaps the belt is sticking down in the clutch or not sliding to the top of the split pulley on the transmission input. Also when checking the clutch I saw very minor corrosion on the front pulley which I sanded with 200 grit emery cloth. I am wondering if closer to the shaft is corrosion causing the belt to stick.
Remove the clutch and the outer cover. It probably has a broken spring or roller arm. Parts available possibly from Quality Drive Systems. I can’t locate the number right now.
In your opinion would this be the primary (engine) or secondary (transmission ) assembly? I have a fair amount of some types of wrenching experience but clutches, transmissions baffle me. What manufacture clutch would be in a 2003 Max II with a 23 hp Kohler engine? Thanks.
Trying to rationalize how the clutch works it would seem that in order for the machine to creep at an idle (again only by times) that the primary (engine) would have to be the one sticking. Would this sound reasonable?
Well I finally got the courage to tackle my sticking clutch. I took the belt off and started it up. I found with very little revving it closed completely and stayed closed. I believe by some of the sounds I have been hearing that the belt in place actually helped to spring open when shut off as I could hear a sound like a bear trap slamming shut. When it was stuck open I could see inside and keeping my fingers back I sprayed it down good with deep creep. If I take a bar with relatively little effort it will snap back in place with a good snapping sound. It looked clean enough inside and no parts falling out. When running as said with a slight rev it closes completely and stays closed. When I rev the engine up I can see the centrifical force snaps some fingers out to grab the drum as I suspect it is supposed to. To get the clutch off I see I have to pull the engine or at the least unbolt and set it over far enough to the right though I don't know if that will allow a puller if needed. I can't seem to find any information on this clutch system and I have searched this forum fairly thoroughly. Any ideas on what I am up against machine is an 03 with around 600 hours.
Hey EldonC,
First, never run the drive clutch without a belt on it as it will damage the outer case where the fingers ride, and then it gets stuck closed.
as for your creeping at idle, sounds as though the belt might be a bit too tight. move the engine touch closer to the driven clutch.
There are "specs" for the belt tightness, but its really a feel thing.
to tight and belt squeals and machine creeps, too loose and not top end speed or low end torque.
use a dry graphite spray to lube the inside of the clutch, where the fingers are, use also for the driven. keep the spray off the belt faces of the clutches.
Thanks Mike, I appreciate your advice. I was not aware you should not run it without a belt. I did about three quick stop/starts so I hope I didn't damage it. It did indeed stick closed but with a gentle pry it snapped open. I will install a new belt and try it again. I used to set the belt by spec of I think 1 1/4 inch deflection but then got so I did it by feel. It has been sticking well engaged at an idle, trying to overspeed the machine more than the engine had fuel at an idle for and when shutting down I can hear quite a trap like snap which I believe is when it snaps open. Then other times it clears. I can't even tell what the make and model of the clutch is. My machine is a 2003 Max II with a 23 hp Kohler.
