https://www.bearingscanada.com/mobil...m-p/uc305.htm=
For any Canadians looking for inner bearings these will do the job. I'm in the middle of replacing bearings all around on my vanguard 2. The only gripe I have with them is the tolerance for the inside diameter is slightly small by .02 of a millimeter so the step down on the axle needs to be sanded down to compensate. Other than that they fit well and the inner race is a little thinner so the ball bearings inside are slightly larger. Hopefully that means they should last even longer then stock.
