The problem will be with clearance. You will have to utilize a heat gun to reshape the lower body or use a similar method. If you prefer to not do that, 22" Argo tires will work with Adair tracks without modification on a Max4.
I understand heating it up and reshaping it but once I get the plastic hot what would I use to actually reshape it? And how would I be able to do it evenly??
You can use a curved board to shape the body once the plastic is heated. If your Max4 has a bump out on the side, you may have to adjust that as well or use wheel extensions to get the tracks out from the body.
Forum member K.G. Hills did different body reshaping technique by suspending his Max4 from ceiling beams and then welded in a support bar to retain the clearance.
