New to Argos. Any help would be awesome
Last edited by Mike; 09-16-2016 at 06:00 PM. Reason: moved thread from "Parts for Sale" forum to "Wanted" forum
Are you selling a clutch or looking for one?
Please post your model, engine and if possible belt number.
Looking.
I'll have to see if I can find anything tomorrow. Thanks for the reply
I got an 89 I/C & a 99 Conquest. They have the same trans input shaft hence the same driven clutch. I needed a new clutch recently and could only find what was needed from an Argo dealer or a placed called Richards Relics. Depending on conditions of the faces of the pulley's where the belt rides if they're ok rebuilding the clutch (replacing bushing, spring & ramps etc.) is not hard to do depending on how tool equipped your garage is and your skills.
I whis I could rebuild it. When I tried removing it the housings broke it is completely seized to the shaft.
A couple of pictures may help also, if it is a Tecumseh there are 3 clutch set ups, Magnum had at least 2, Conquest had 2 but are interchangeable.
