Vanguard 18 transplant needs a clutch
Results 1 to 9 of 9
Thread: Vanguard 18 transplant needs a clutch
    May 2011
    St. Paul, MN
    51
    I've got a used Vanguard 18 that I'd like to put into my Attex Chief 400, but it needs a clutch. Can anyone recommend what clutch I should look for? I will be using this for trail riding. I've been searching the forum but haven't seen anything specific mentioned.
    Thanks in advance for any help you can offer.
    Tom
    "Obsolete doesn’t mean a thing isn’t any good - it just means they don’t make it any more.”
    - Von Dutch
    Buffalo, NY area
    2,968
    Nov 2009
    Michigan
    730
    I have a Comet 94c that was in the for sale section. Its almost brand new.
    statesville, north carolina
    2,604
    [QUOTE=hydromike;215619]Buy this. Don't change a thing on it. Bolt it on and go.
    [url=http://www.mfgsupply.com/302405a
    agreed. a lot of people will tell you that you have to change the spring in the secondary, but you don't HAVE TO. I have several machines running the 2 stroke spring that work quite well
    Nov 2009
    Michigan
    730
    I agree you dont have to change the secondary spring but like chiefdiesel found out in heavy loads and climbing he had issues.
    May 2011
    St. Paul, MN
    51
    Thanks for the recommendation. I'll order one up. I won't be hauling any heavy loads, but there could be some hills in its future. I'll tackle that later if it becomes an issue.
    - Von Dutch
    2,604
    In a machine that light, it probably won't ever be an issue. My Wild Wolf with the 18 Vanguard (same basic machine) goes anywhere I point it and has never had the spring changed
    5,055
    Even places it shouldn't, even with lights.
    May 2011
    St. Paul, MN
    51
    MFG Supply ships fast!
    - Von Dutch
Tags for this Thread
