Does anyone know of or have any ideas on mounting a brush hog to the front of an Argo? I got the snowplow but would really like to use my Argo to clear brush.
I saw a brush hog made in Finland but it cost about $6000.00
Interesting thought i had the same idea only with a snow blower they pull behind atv mower attachment if you could find something along that line that wasn't to heavy and with its own motor could be adapted to mount on the Argo snowplow mounts and the winch used to raise and lower it to its own front wheels it would take some fabrication skills and its attachment point would have to have a degree of "float" for the ground unevenness weight of the attached mower is key.NCT
i think one of the ones you tow behind atv's that have their own motor could be adapted . it could be mounted to the front snowplow bracket i think . the key would be to have large rubber tire casters on each corner for manuveuring set at the right height . that way the cutter would easily turn with the aatv . the front bracket would need to be able to float to work on changing terrain as you mowed . and each caster would need to be the swivel kind . just some ideas jboy
