5 x 4.5 is the bolt pattern if I remember correctly.. the manual does say. 12''diameter x 8'' wide. Last time I checked it will cost at least 60$ a wheel. Wheels & tires get high x8.
What's the overall tire size on this machine? Always wanted to know.
That's a standard jeep pattern, same as Coot. Rims can be picked up real cheap all day long or even free, but 15" tall!
The overall size of the tire is 23" max they come on 12'' wheels. I put 23 diameter by 10inch tires on my 12x8''wide rims. The tires are less than an inch apart. Used a 8inch wide tire on the front bc the front axle is a tad higher than all the others.
