Help with engine mounts for V-Twin
Results 1 to 4 of 4
Thread: Help with engine mounts for V-Twin
    Sep 2007
    Melbourne, Australia
    10
    Hi Guys, I have an old Max 2 with a blown up Tecumseh 16hp in it. I'd like to pop a 18hp Vanguard in it as with most of the pics here! I noticed that the mounts, at the clutch end have a step in them. Can anyone help with the dimensions of these two strips and perhaps a profile shot at the stepped end? Thanks.
    Jan 2012
    Indiana
    5
    I was looking for the same thing in my old max. Did anyone answer you on the set-up of the motor mounts. I was planning on taking mine into Maintaince work shop and fabing some tabs for the rubber mounts to which a a couple of plates with elongated slots for poistion.
    Jan 2009
    North Mississippi
    158
    I converted a Tecumseh Max to a Kohler V-twin. I will have to search my notes for exact dimensions, but all I done was take the old mounts and drilled more holes to fit the Kohler. I found the dimensional drawings for the Tecumseh somewhere and got the Kohler dimension off of their website. When I laid out how the mounting holes should be I had to take in consideration of the height of the output shaft so that I could use the same belt. You could also buy the Briggs mounts from RI, I think they will bolt right in to place, but I’m not totally sure. If you go that route Jay at RI should be able to confirm this.
    hey! what model was the kohler ? i need to replace my 18hp and have no idea what to replace it with. thanks
