got a hustler 950 for 500 bucks everything intact on it except broken chain for front left tire got that fixed down to the engine now looking for the drive belt for the 18hp kohler 2 stroke with t20 trans
Not sure if the #'s are in this publication. http://www.6x6world.com/images/6x6-h...ATV-Manual.pdf Click the link and check it out. are ya sure about the 18hp 2 stroke or could it be 18hp 2 cyl. 4 stroke?
I think I'm pretty sure it's the k440-2ax
okay I read the nameplate it's a model 900-hk serial mfc-127
$500? Wow, good job! PICS!
I'm having a hard time trying to find out how to post a pic on here
Welcome Chasebly. To post pictures, click on the "go advanced" tab at the lower right hand corner of the reply to thread window. Then scroll down about mid way and there is a button to "manage attachments". Click on it and another window will open and in the top right hand corner you will see "add files". It has instructions, but you click on it and navigate to your pics, select the pic and it will download into this window. Then drag and drop the pic into the lower portion of the window and click "insert inline". A code for your picture will show up in your message text, but it will convert to an actual image when you post the message.
this is my hustler in the process of cleaning and work. still have a problem finding a belt that fits and the carb is junk
