Carrier Drum bushing fit
Results 1 to 5 of 5
Thread: Carrier Drum bushing fit
    Aug 2019
    Merrifield MN
    34
    I thought I should repost this since I was wrong about the part I was trying to get info on it's not the Ring gear drum (sorry)
    Aug 2019
    Merrifield MN
    34
    The carrier drum is the one I'm looking for info on, I did measure the center plate shaft and the bushing in the carrier drum with calipers and came up with 1 to 1.5 thousands clearance, but I feel I should use a bore gauge to get a good measurement to know for sure.
    Fairbanks AK
    1,460
    .002” is still ok. I see a lot looser than that running fine. The new bushings used to come unsized. You press them in and have to fit for clearance. The case bushings that hold the ring gear drum have to be fit in a mill or with a boring tool.
    Aug 2019
    Merrifield MN
    34
    That's good to know Thank you.
    Aug 2019
    Merrifield MN
    34
    I got some good measurements with a dial bore gauge and came up with 1 to 11/2 thousands clearance which should be fine.
