Hustler 980 tall tub build
Page 9 of 11 FirstFirst ... 7 8 9 10 11 LastLast
Results 81 to 90 of 109
Thread: Hustler 980 tall tub build
  1. #81
    Feb 2016
    Mississippi
    1,108
    JB I received the bands today and they are going to be perfect. Thank you very much!
  2. #82
    2,641
    dob...your very welcome ! you know it's too bad we don't live closer to each other so we could ride and work on machines together . i'm sure many members would like to be closer to a fellow enthusiast . i'm sure the no. carolina '' busco '' gathering is too far for you . it's the only chance i get to ride with others. keep us posted on your project . johnboy va.
  3. #83
    Feb 2016
    Mississippi
    1,108
    I would like to make the busco trip sometime. I have family in sanford and holly springs NC, so it could be a dual purpose trip.
  4. #84
    Feb 2016
    Mississippi
    1,108
    Going to drop the trans back in tomorrow and hopefully go for a test run.
    Thanks to john swenson and transmission crafters the plungers now are in the right position
    Notice this case has been sleeved at the plungers and also has a bushing the shifter rides in.
  5. #85
    Jun 2016
    Newville, PA 17241
    568
    My case has sleeves on each shifter hole, now I will have to look closer at the plunger holes.
    DanW
  6. #86
    Jan 2014
    clifton IL
    813
    Attachment 18200
    Attachment 18201
    Hey Dirtdobber I've noticed any T20 that I've came across from Jonesboro Arkansas have always been sleeved in plunger and shifter holes. Just a FYI.
  7. #87
    Feb 2016
    Mississippi
    1,108
    Thanks dave. I was wondering if this case had been worn out and repaired but apparantly not.
  8. #88
    Feb 2016
    Mississippi
    1,108
    No fun for me yesterday. Installed the transmission and new driven clutch only to discover the belt rides higher in the new clutch than it did in the old, about a quarter inch difference. So, this makes my belt too short now. So, I have to either get a slightly longer belt, or shim the new clutch open just a hair.
  9. #89
    Feb 2016
    Mississippi
    1,108
    Got the 980 all back together and went for a spin this afternoon. Still have some tuning to do. Here's where I am:
    * The new driven clutch came with a green spring, so gave it a try. I wish I had changed it because it stays in "low gear" waaaay too much.
    * I've got a geometry problem with the diamond shifter on the right hand side. I had this problem in the first test run, but I was hoping that changing to a different case would correct it. When in forward or reverse it won't pull itself around to neutral unless I give it a nudge. Nothing wrong inside the T20, it's just a geometry problem.
    * I'm more than pleased with the engine compartment air flow system. It was 91 degrees today and the surface of the engine compartment was within 5 degrees of the opposite end of the machine.
    * I'm going to make some radiator modifications. The engine temp was climbing more than it should in my opinion. I did not get it hot. First, I need to make a small shroud to take up a little space between the fan and radiator. I'm losing a little air here. Next, I need to fashion some type of louvered cover for the radiator. It is exposed to direct sun, so I suspect that is robbing some of its heat exchange capacity.
    * Band chatter. I'm running type F fluid with 4 ounces of friction modifier, but still getting some chatter. Not sure what to do about it.
    * I didn't get to float as much as I would have liked. It was windy on the lake and I didn't want to risk the wind taking me "out to sea" or pinning me in some trees. I'm just not comfortable yet with this machine. It is not very stable when floating.
    Other than fine tuning those things, I like it! This thing is is a beast compared to the 950.
  10. #90
    Jun 2016
    Newville, PA 17241
    568
    Awesome to hear! I can't wait til I'm down to the little stuff and fine tuning.
    Would redrilling the hole in the diamond change the geometry enough to cure the sticking problem?
    DanW
