Meh Max too
Page 9 of 10 FirstFirst ... 7 8 9 10 LastLast
Results 81 to 90 of 97
Thread: Meh Max too
  1. #81
    Jul 2021
    Knee Vah Duh
    91
    So after several days of deliberation, I?m considering trying to clean up the Mikuni carb from the snowmobile and fitting it to the Briggs to try to save some time and maybe actually get to drive this monster around before the snow completely melts off.
    I was able to finally find the engine sticker on the bottom of the engine cover when I pulled it off to troubleshoot the no spark issues the other day. It is in-fact a 16 horse Briggs and Stratton engine with a model number of 326431.
  2. #82
    Jul 2021
    Knee Vah Duh
    91
    I have been researching carb rebuilding and found that people are using pinesol to clean carburetors.
    https://youtu.be/OcvDrUtz3r4
  3. #83
    Jul 2021
    Knee Vah Duh
    91
    Saving this for the future, incase I decide to go ahead with the carburetor swap.
    https://youtu.be/oKhMxeNO2cI
  4. #84
    Jul 2021
    Knee Vah Duh
    91
    Well I finally had some success! I got the better of my two snowmobiles running! I had to clean the carb real good and then replace the drive belt. It still needs new skis and a few other things but I learned a lot. Maybe it?s enough yo get the other carb cleaned and put on the briggs engine?
  5. #85
    Jul 2021
    Knee Vah Duh
    91
    I cleaned up the ?new? carburetor and it?s all ready for the install. I?m gonna have to build an intake adapter. I imagine that I?ll just use 1- 3/8? exhaust pipe and make a couple flanges out of some 1/8? plate. Then I?ll fit them, weld them all up and see if it was for all naught or not. I might end up having to buy a new throttle cable, not sure yet.
  6. #86
    Jul 2021
    Knee Vah Duh
    91
    Earlier today, I fired it up and adjusted the carb so it?ll idle again. I had the idle set too lean. I should probably install the mikuni carb already. My procrastination has over taken me this spring?
  7. #87
    Jul 2021
    Knee Vah Duh
    91
    Well I went and bought a Mitsubishi Minicab because the add said it had a 3 cyl Kubota diesel. Well turns out it was a 4 cyl kubota and it?s way too big for the max. I knew it was and bought it anyways because the price was right. So now I?m trying to figure out if I want to sell the motor and buy a smaller Kubota for the max or try to get the stock Mitsubishi 3 cylinder that I also got with the purchase, to run and put it in the max because it?s like 50 hp and is liquid cooled.
  8. #88
    Jul 2021
    Knee Vah Duh
    91
    I finally got around to installing the mikuni carb. It runs but doesn?t idle that good. I also need to order a new choke cable and spring. It?s rusted and gummy inside the sheath. But it sure sounds good and revs really fast now. I think once I get it set up it will actually run pretty good. I?m going to order a wide band O2 sensor then I?ll order the appropriate fuel jet kit and cables. I?m getting kinda excited about it again lol.
  9. #89
    Jul 2021
    Knee Vah Duh
    91
    I ordered a choke cable assembly for a honda rancher because the cable and the housing looked like it will work for the application. It was $10 so we?ll see if I can make it fit. Should work out though.
  10. #90
    Jul 2021
    Knee Vah Duh
    91
    I installed the new choke cable and the carb is flooding out. I need to do more research on the type of jet kit I need and start trying smaller jets for the idle. Also the float is starting to deteriorate and is sending particles in to the fuel. That?s definitely not helping either.
