The suburban Hustler
Page 7 of 7 FirstFirst ... 5 6 7
Results 61 to 66 of 66
Thread: The suburban Hustler
  1. #61
    Jul 2011
    Garner, NC
    865
    Hustler belt
    Can you supply me with the belt information that you used on your hustler build,??
    BIGFOOT ALUMNI
  2. #62
    May 2016
    Buford, GA
    72
    I went through a few different belts before I settled on the one I have. I tried ordering heavy duty and powersports belts based on the dimensions I needed, spending over $100 on a couple of them, and they either were still wrong or broke very quickly. Surprisingly, the one that worked was a seemingly standard belt I found somewhere on here. It is an A&I Products A-301195 K, suggested for a Comet clutch (which I have).
    Here are some choices:
    on Amazon
    on Ebay
  3. #63
    Ontario-Prince Edward County
    997
    The Suburban Hustler
    Quote Originally Posted by SeanD View Post
    I've been "Hustling" to get the last things done on the 6x6 before it's ready to sell. I don't know why but I often seem to cope with the unfinished bits right until it's time to sell, then everything gets done at once for the next guy.
    The gas tank bolts needed some reinforcing, and my two year old needed something to hold. I went about building a grab bar for the front.
    I was very excited to finally use the pipe bender with success.
    Then there was the engine cover. I started it months ago but abandoned it when it didn't go my way. In the meantime I came up with much better ideas. I added solar to keep the battery topped up, and I found a very cool 14 gauge perforated metal at HD. Way better than the expanded metal I thought I was going to have to use.
    The floors were my last problem. I had done most of the cutting and mounting earlier to keep childrens' shoelaces out of chains and sprockets, but again- never finished them. I found a garage floor diamond plate looking rubber mat at Auto Zone that won me over.
    And there she is, up on the Atlanta Craigslist for eleventeen gazillion dollars!
    Wow. Your Hustler is as others have said,truly a beautiful thing. Rereading this entire post starting in June 2016 is a story that is worth reading. Thanks for the posts.
  4. #64
    What did you use to put the top half and bottom shell together? Seems like you can take off and put it on as needed.
  5. #65
    May 2016
    Buford, GA
    72
    It's sandwiched together like it would normally be, but I added that steel angle band around the edge, which just bolts together through the same holes. Does that make sense? hahaaa! It does come apart with about 50 bolts, but it's not easy.
    If you look for "body band" you'll find how to cut and weld up a big bumper to protect the outer edge. It's nice to be able to run against trees in the woods without the carnage of broken 45 year old plastic.
  6. #66
    Sean,,after your PM, I came and read this entire thread. Your attention to detail is Insane!!! Beautiful Work !
