Meh Max too
Page 5 of 10 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 41 to 50 of 97
Thread: Meh Max too
  1. #41
    Jul 2021
    Knee Vah Duh
    91
    Thanks guys! I?ll measure them to see if they?re different lengths and get a low pressure gauge. I tried to get them all at 5 psi. What should they be at?
  2. #42
    Dec 2018
    Muskoka, Ontario
    95
    Mine run nice at 6,7,6 . It's an argo vanguard 2. It's all about finding the balance between the tracks being not so loose as yo slip , and not so tight as to kill bearings and axles. In my case not so tight/tires inflated, that the tires are too rounded in profile to hold the tracks on.
  3. #43
    Jul 2021
    Knee Vah Duh
    91
    I put the track back on, took it for another test drive. I got 3/4 way around the house before it fell off this time lol. I made sure the tires were 5,6,5. The tire guides look like they have about 3/4? of space between them and the tires. Should they be touching the tires or have some space?
    I can?t help but think the tire guides are too short. Maybe I could get one of those grinder blades from Harbor Freight that?s wrapped in a chainsaw chain, then cut off all the rubber nobbs from the inside of the tracks?
  4. #44
    Dec 2018
    Muskoka, Ontario
    95
    My tire guides are touching the tires both sides at all times. I would defidently cut the knobs off the inside of your track if they are causing the wheels to ride up higher.
  5. #45
    Jul 2021
    Knee Vah Duh
    91
    After thinking about it all night, I?m gonna reinstall the track and try running the tires at a lower psi. I?m gonna try 3/5/3 and see if that helps. I reread your last post Facemelter and 5/6/5 may have my tires rounded out too much, they?re rawhides.
    Edit: I also replaced the chinee spark plug with a Champion plug. It’s starting up and running fine now. We’ll see what it does today.
    I appreciate the help, everyone!
  6. #46
    Jul 2021
    Knee Vah Duh
    91
    Well since I can?t figure out how to post more pictures, here?s a link to the build thread I started on Pirate 4x4.
    https://www.pirate4x4.com/threads/ma...#post-45035704
  7. #47
    2,661
    rowdy ...just saw your pictures of tracks on your max 2 . nice job of making them . i agree with the removing the knobs on the inside rubber . it's keeping the belting from gripping the tire i think , especially if the knobs are higher than the guides and the nuts holding the guides to the belting. great job ..just keep experimenting . my tracks work good but can come off because my tires are a bear claw type tread ..not great for tracks. i am running low pressure so the tire is flatter and more of it is on the track . that helps . johnboy va
  8. #48
    Jul 2021
    Knee Vah Duh
    91
    Thank you sir! I have tried to make them look professional and to be strong. I hope to use it in the mountains so I want it to be reliable. I bought a carving wheel for my grinder. I?ll experiment with taking the knobs out and probably shorten the track some if it still pops off.
  9. #49
    2,661
    looking at the pics again ... the guides look a little short , not coming down on the sidewalls very far . also is the distance between the guides wider than the tire? if so , less air so the tire is flatter and wider may help . if the guides are much wider , add some longer flatbar to them to get more on the tire on the insides and that will shorten the width too . trying the grinding is a good place to start though . just takes adjusting jboy
  10. #50
    Dec 2018
    Muskoka, Ontario
    95
    +1 to getting the tire wider in the track and getting the guides a little tighter. The less slop sideways the better. You just gotta get the balance figured out for your tire/track combination. Sounds like you almost got it.
