What is the size of the bolts for the grousers..just curious..
Here are the new mods to my channel tracks, put them on every 2nd channel (50 total), added 2 3/4" tuners also.
Front and rears are at 7lbs,
Mids are at 5lbs
Just traced the curve of the one crosser on a piece 1/8" board then did it again till it seemed to fit, added them to the outside of the crosser and made them a lil' bit shorter/lower to allow for the welds not to dig in the belt/tires and the cleat not catch in when turning on hard surfaces . Had a friend water jet and weld them on. He said it should add strength by creating a gusset. They are 12ga .104" .
Installing them I had to take both the front/rear tires off cause the added cleats wouldn't clear the tub with the front/rear tires on. Removed a cpl crossers (just on the outside) and that allowed for easy installation for the rear tire by pulling the tracks back till the belt was touching the front axle.
Seemed to swim ok at lower rpm (not great) but the weight of the tracks on the argo made it a bit nose heavy, wasn't moving too quick. At high rpm they threw plenty of water in the back of the tub but didn't improve speed at all. Think it kinda went slower.
Hope you guys like them.
IMG_20140925_170708.jpgIMG_20140925_170550.jpg20140923_142323.jpg20140923_142303.jpg20140923_142254.jpg
anyone have any ideas. i would be curious to know what a metal stamping co. would charge per tire grouser bar like the channel ones after the cost of the die. the steel channel itself is maybe around $ 2.00 a foot ? obviously the more quantity , the price goes down. johnboy va.
P1010015.jpgP1010013.jpgP1010018.jpgP1010023.jpgP1010016.jpgFinally put my Chanels on my 2004 Conquest. It was time consuming getting them sized properly and I felt that the overlap joint was too thick and came too close to the axle extensions for my comfort so i went with the Flexco 550 hinges. Marcel told me to have 2 1/2" sag under the center tires, but I have about 2 1/4". My center tires are bigger than the end ones by about 1/2 an inch though. I am going to put some type of paddle/cleat in-between every other grouser, but I don't know what yet. I am running 22x8x11 Carlisle Stryker tires, Adair Track Tuners on the centers and 2 1/2 Adair spacers on the end axles. I also upgrade the front axles and bearings to the HD. Here are some pics:
I think if you made the tooling yourself and had them pressed on a hydraulic press the cost would be pence. Setting up a mechanical press would cost more than doing the job.
We used to make tooling ourselves for a press we had (200t hydraulic) and it was pretty simple. Just make the shape you want (top and bottom), clamp them together and drill hole in each corner. We used to just drop bar in the drilled holes then to keep everything aligned when pressing.
Good job there thorn. Now your cooking. Yes it takes some time to get it all just right but in taking the time now you have no worries. It a good idea to go the HD axles one less thing to go wrong.
Around here we are just waiting for the snow to start falling. The freezing level is coming down to about 5000 feet, soon the snow will start falling in the hills.
Hmm, getting chilly here as well, had to put a jumper on today on site
MUSCATEER 6x6
MUSCA TUR BOTA then eh?
94 F350 4x4 7.3 IDI ZF 5sp
Al "Camo pants"
I believe the track sticks 1/2 inch above the tire which is the thickness of the crosser..the crosser is 1.5 inch wide by 1/2 thick
