That is not the new Avenger tire we just tested the first ones out of the plant I purchased them yesterday and we tested them today check youtube under AAA argo
I posted 4 videos on youtube to view the first set of new Avenger tires in test they performed exceptionaly well with confirmed GPS speeds 5.4 kms in high gear and 5.0 kms in low with the 3rd. tire reversed we got top speed of 5.0 forward and 2.4 in reverse we tried all configarations this was the best overall result with all tires facing forward there was no reverse speed to record the GPS actually said 0.0
link to firstallin's video above. fast forward to 6 minute mark. think it's widescreen footage that youtube displays in 4x3, so things look a little tall and narrow.
Your test results for these new tires should blow away ANY need to buy that China unit, Argo knock-off!!!! Continue supporting North America's workers & OUR economy!! Who needs built-in propulsion, at the cost of jobs?!? These tires will help us older unit owners as well! I'll budget a set for my Conquest, even if it's one tire per month!! I've got fair tread depth for one more year on my rawhides & then, keep em around for winter track use.
Ken asked if i would post this video of the new tires so here they are in action. Hope you guys enjoy. They work great!
3.5 mph measured with gps. Trials with one person=3.5 Speed was slower with 3 people but still very impressive, speed was recorded on the ride.
Ok, here are the stats on our tests related to AAA Argo video. All results are verified by GPS.
Argo Avenger 700 (not EFI)
One person 280 lbs.
Full Tank of Gas
Estimated 3-5 mph wind
Temp -3 degrees C
Some Ice on Pond
5 psi in tires
WATER TESTS
Best Run with Rawhide III's.....2.9 k/hr or 1.8 mph.
Best Run with New Avenger Tire......5.4 k/hr or 3.4 mph
Reverse Speed with New Avenger Tire....0 k/hr or 0 mph
Directional Control with NAT (New Avenger Tire) Excellent (steers like an ATV on land)
We then tried to rotate 2 tires backwards (one axle) to get some reverse.
Front Axle:
Best Run 4.4 k/hr or 2.7 mph (loss 1 k/hr or .62 mph
2nd Axle:
Best Run 4.9 k/hr or 3.0 mph ( loss .5 k/hr or .31 mph)
3rd Axle:
Best Run 5.0 k/hr or 3.1 mph (loss .4 k/hr or .24 mph)
Rear Axle:
Best Run 4.0 k/hr or 2.5 mph (loss 1.4 k/hr or .87 mph)
Best Position for reversed tires: 3rd axle from front
This will give you 5.0 k/hr or 3.1 mph in forward, and 2.4 k/hr or 1.5 mph in reverse.
General Observations:
1. Hardly any difference in speed whether using Low or High Gear
2. Tires are so efficient in water that they really eat up the HP.
3. I feel we could have achieved faster water speed with more HP. or improvements to the drive train to increase tire RPM.
4. It looks like this tread design does not require that 50% of more of the tire to be above water line to achieve speed.
I will be posting some stills and more video of this testing in a couple of days. Sorry about all the detail, but for those who are interested these are the verified statistics.
