Wild wolf 295
Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 94
Thread: Wild wolf 295
  1. #21
    Jun 2017
    Robinson, IL
    72
    Update. Removed engine to set timing and gap with buzzer and dial indicator. Replaced carb as it was leaking bad. Have spark and sprayed starting fluid in carb and in plug hole. No change. This thing won't even try to run. It does seem to spin a little faster when spraying either in carb. Honestly I'm at a loss. Any suggestions from the experts?
  2. #22
    Jun 2017
    Robinson, IL
    72
    I do have a junk battery in it. Just spinning it over with a charger. Could that be an issue?
  3. #23
    Dec 2012
    Youngstown, Ohio
    1,003
    Did you try starting it with the recoil? I had a single once that had a starter on it but it was spinning the engine in the wrong direction. Where are you located?
  4. #24
    Jun 2017
    Robinson, IL
    72
    I've got the recoil off so I could year the engine down. The engine is spinning the same direction as the recoil. I'm in Robinson Illinois.
  5. #25
    Dec 2012
    Youngstown, Ohio
    1,003
    When you set the timing did you have the advance pulled back and held in place?
  6. #26
    Jun 2017
    Robinson, IL
    72
    Yes. The timing was advanced. The only part I question about the timing procedure is did I read the dial indicator correctly. I think it was just over a complete revolution of the dial BTDC.
  7. #27
    Dec 2012
    Youngstown, Ohio
    1,003
    Between .118-.138 so it should be over a revolution. These are finicky so when I do it I check it a couple of times. Check your spark plug gap again too. You had spark before so I think it is something out of adjustment.
  8. #28
    Jun 2017
    Robinson, IL
    72
    I will say this. Maybe this will help on what direction I should go. I bought this as a non running project so I have never heard it run. Could it possibly be losing spark under compression?
  9. #29
    Dec 2012
    Youngstown, Ohio
    1,003
    No, I don't think so, if you have spark and fuel, then its timing if the compression is good.
  10. #30
    Jun 2017
    Robinson, IL
    72
    Compression is good. If I crank it with my hand over the back of the carb I get fuel running out the back of the carb by my hand. Does that sound normal. Put the Piston in with arrow towards exhaust. Just drawing at straws now
