Custom made volkswagon powered 8x8 with sea doo pump
Page 3 of 32 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 316
Thread: Custom made volkswagon powered 8x8 with sea doo pump
  1. #21
    3,285
    chris davison
    Looks like you,re heading down the home stretch now.
  2. #22
    Sep 2007
    London, Ontario, Canada
    376
    Chris, that looks real good, I can hear it running. Very nice arrangement.
  3. #23
    May 2008
    Putnam, NY
    1,074
    Looks nice. I commented on the photo you posted on the VW motor thread, but I see you have been quite busy. Very nice work.
    Attex Super Chief - Sold.
  4. #24
    That means alot comming from someone as experienced as you Ray
  5. #25
    Can you Imagine sitting around the campfire around the lake late at night and suddnly you hear a volkswagon bug out on the water putting around with 4 big head lights.
  6. #26
    Just purchased a solid aluminum fan pully to bolt a 1.5 in timing belt pully to and found on ebay 5 1.5 in. pullys 4.75 in dia. for $78.00 just what I needed to power the Sea doo pump. Hopeing for the big test this summer.
  7. #27
    Well iv'e bolted the winch on the front revised some support bars. My exhaust sys. has arrived and will need modification. Just waiting for some cash to do some machine work on all the parts. I have also recieved some 1/8 Delrin to go under the axle chains so they dont rub the bottom of the hull so now I can install all the chains on the axles and start to devise chain tentioners.
  8. #28
    Wow what drag I have so many parts and so much I could do and Im stuck working 7 days a week on graveyard some days 10 hrs. thankfully I finished Hydraulic school. Hey Ray I have an Idea on your props
    in the water if you cant lower them below the hull can you weld in a 6 in diameter aluminum tube thru the hull from front to rear ending dead center of the props? or even start them some where in the bottom
    tilting up to the props? this would make reverse effective also. But they would be really effective if the prop was inside the tube.
  9. #29
    Sep 2007
    376
    Quote Originally Posted by chris davison View Post
    Hi Chris, I've been just sitting back and enjoying your progress. Regarding the duct idea for the props, I considered that approach back in my Hoot days, as the Hoot has a square support member (duct) running down the middle intergrated into the floor. Also this is the method Hydratrek uses to supply water to it's dual prop setup. It works fine. But my problem was more related to prop rpm, gearing up from the axle doesn't give you enough rpm to do it justice, no matter what pitch the prop is. The Hydratrek doesn't have that problem because they use a hydraulic motor, and use large fine pitch props.
    I think you have a much better chance to get some decent water speed using a jet pump, you should do a little better than the Chinese Argo guy that uses a similar setup, because of your hull design. I do have a swing down prop design, but it adds more complexity and didn't pass the cost/benefit analysis. IMO, the only way to get "real water speed", is to raise the tires out of the water, and design for a semi or planing hull. Chris your half-way there. Put that hydraulic course to use, I'm sure you know what I'm talking about.
  10. #30
    Like I said in another post If I had it to do over again I would use trailing arm suspension with wheel motors( Hyd of course) that way i could rotate the suspension right up out of the water. Ive never seen a hydrotraxx or coot or hustler or anything but an Argo conquest and thats when I decided to make my own. I dont think there is anything out there like what I want.
