Homemade tracks using snowmobile tracks
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 42
Thread: Homemade tracks using snowmobile tracks
  1. #21
    Sep 2007
    London, Ontario, Canada
    376
    Salvage
    BC, Not too far from me is Snowline Sports Snowline Sports
    Check out the pic of their track inventory. I will be checking with them, before winter to see what they have.
    Also another source is conveyor belt manufacturers, many have very interesting patterns, some with raised chevron style patterns that swim. The only downsize is most don't have lateral stiffeners and flex (curl) up outside the tire width. But if you install lateral cleats they should work out OK.
    I've sourced out one company that makes what I want but you need to buy it in 100 ft. rolls, so maybe a couple of us guys will work together and split the costs. I will update this thread as the fall approaches.
  2. #22
    Jul 2009
    grand junction co
    38
    if you are on the cheep for convayor belting go to your local gravel pit that is where i work and we throw the stuff away some times. ask for used belting and they might sell it or give it to you. also there ie a product called flexco this is what holds a convayer belt together it will work for one of the splices on your snowmobile trax you will need the argo splice for the pin but it will save you125$. I looked at the argo dealers supper tracks for the centaurs and thats what they use convaer belt with angel metal bolted on. it is also what they use for the plastic extention kit.
  3. #23
    May 2008
    Ontario,Canada
    489
    I too am looking into making a homemade set for an 8 wheeler, but i think the cost will be higher than what first thought, lets say im building a set like BW6's friends for a 6x6, he has 22 guides/side thats 88 guides for the set at $4 each thats $352 just for the guides then if each splice kit is $125 and you need 4 then thats another $500 then i still need to add taxes, then buy some old sled tracks along with hardware for the guides etc. I was thinking of just using what they use to join conveyor together for joining the tracks and making my own guides from galvanized steel like the escargo tracks have, i have a metal bender at work so that would be no problem but still have to think of a good guide design and do some resarch. Any thoughts? Input?
    "Argo 8x8's only" type of guy
    "old school Argo expert"
  4. #24
    Apr 2009
    Ontario, Canada
    92
    I want to make some tracks as well for my Max.
    I will need to put on a new set of tires as well because the 22" ones are to big.
    Let me know how you make with your tire guides. I will be very interested.
    Cheers
    Max.
    Maxheadroom..!!
  5. #25
    Aug 2007
    near olean, ny
    1,083
    Smile making tracks...... literally,....
    see amphicat tracks by Don in gallery or my photo of black cat with tracks.might cost you 250.00 to make them, they don't roll or fall off either
  6. #26
    Aug 2007
    near olean, ny
    1,083
  7. #27
    Apr 2009
    Ontario, Canada
    92
    More Details Pls.. Pls.. Pls..
    Mr. Amphiman..
    You said you could take some close up Pic's for me to see how the Rubber attached to Chains..can you do that and share with us..
    Where did you get the the Rubber from..??
    Pls help.. I really would like to try building these.
    Cheers
    Max.
    Maxheadroom..!!
  8. #28
    tacks
    Hey Guys, great to see those tracks. I really need a set for my Bigfoot. I sold my plastic tracks this spring. Hope the video will be available. I am in the Ottawa Valley. Need to do something asap.. Thanks, Mark..
  9. #29
    Aug 2007
    near olean, ny
    1,083
    Smile tracked down LOL
    hi! these tracks are made of conveyor belt type of material..... the chain part is the same as tire chains for a car or pick up truck, (no cable)
    they hold on the rounded tires very well, you could make them at home too, not spending crazy money for tracks that wear out faster than you think. thses are very replaceable parts too
    This Year, i can't wait until it REALLY snows!!
  10. #30
    May 2008
    Ontario,Canada
    489
    goin to be doin some test bending for guides on the shop iron worker this sunday, material is 1" galvanized tube(conduit) cut in half, ill let ya know how i make out, im hopin if it works that i could keep the cost around $0.60 per guide with hardware and backing plate.
