What RPM Range are You Running?
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 34
Thread: What RPM Range are You Running?
  1. #21
    Apr 2016
    VT
    269
    For my 2 cents worth: I would adjust the belt tension to the 3/4" deflection and see what that does....after consulting this site, and the owner manual, I found my speed/power problems all were attributed to this minor adjustment.
  2. #22
    5,055
    I too would pull it apart, could be someone over wound the spring, spring color will also affect opening force.
    Should you open it be careful, try to count clocking.
  3. #23
    Ontario-Prince Edward County
    997
    rpm range
    I regret that you haven't found an easier answer, it sounds like the clutch needs to be looked at on the bench. It didn't help but I;m glad that you tried a new belt to eliminate the obvious. good luck.
  4. #24
    I have a 2000 Max II, 18hp vanguard, high rev kit, gov disconnected, exhaust restrictors removed and that is it. @5200 rpm clocked 32 MPH with all drivetrain stock.
    I do not have a billet flywheel so I am very careful not to exceed 4400 RPM on normal driving and that is about 25-27 MPH. The extra revs are great when I really need an extra boost of power.
    Larry
  5. #25
    Quote Originally Posted by garretttpe View Post
    Larry
    32 mph would be awesome. I don't think a 14hp Vanguard could ever get there. I would be happy with 25 mph. When you disconnected the governor on your motor, what modifications did you do other than the high rev kit? Did you remove the governor internally or just the outside linkage? I read online you have to install a spring to keep it from revving too high. Supposedly with the governor disconnected, the motor will over rev by itself without touching the throttle. Any info much appreciated. RR
  6. #26
    Reconrokon
    MSAFI65 sent me a email with detail on what to do back in 2015. I cant find that email so maybe you can ask on here or send him a PM. It was a very easy process. he sent a to scale picture of the lingage that needs to be reshaped. and it works awesome.. and only way to over rev the engine is if I do it, no way it can over rev otherwise.
    At idle I am at 800 rpm aprox and no issue's.
    Mods... High rev kit, removed exhaust restrictor, gov bypassed that is it on the engine,
  7. #27
    Reconrokon
    Thanks for the info. I will try to get that information on reshaping the linkage. I removed the exhaust restrictors on mine, but it didn't change anything. If I can get my governor modified, I think that will boost my top end quite a bit.
  8. #28
    Remember
    you will need a billet flywheel if you will be in the 4600+ range for any amount of time. I do not have one but I also do not go above 4400 rpm. 5500 i did for speed test. I use the extra throttle for when I need to get up something really steep, that is where I get the most advantage, I also have a red spring in my secondary clutch which keeps me in lower gear longer and that also helps on the hills and stuff. I would highly recommend the red spring.
  9. #29
    May 2014
    VT
    520
    Defiantly not closing all the way. 2" of deflection seems pretty tight to me. My belt was slipping with 6" of belt deflection. I moved the engine closer and ended up with 3" of deflection. The belt was too tight and it would never slip enough to shift gears. Still had slippage. Moved engine closer. 1" of deflection. Had to start in gear, no gear change possible. STILL slipped! Changed to a newer clutch and problem mostly went away. If only these machines had real transmissions with real clutches.
  10. #30
    I agree with some of the guys here, remove the secondary clutch, very possible it was clocked wrong if someone installed a new/different spring and it is just to tight. and a deflection of 3/4 to 1 inch is what is needed. if the belt is good, the deflection is good, the RPM is good, the primary is working (as it appears it is), then not much else except the secondary..
    Remember this system is designed to be at 100 percent at 3600 engine rpm. so just giving more throttle will only mask other problems. Buying a new red spring is cheap 25 dollars or less and i would also install new slides. a couple of hrs work and a few dollars and the secondary will be good as new. there are threads here that show how to do it.
    My .02 cents
