The suburban Hustler
Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 66
Thread: The suburban Hustler
  1. #21
    May 2016
    Buford, GA
    72
    What is this Busco Beach? I keep looking for spots around me to dip it in water when the time comes. There is this really nice neighborhood with a really nice lake in it that I would love to terrorize.
    Anyhow...
    My HF pipe bender was a total SNAFU. It was more of a pipe folder-kinker-smoosher. I just caved and bought some mandrel-bent J's from Summit. So, now the headers are made. I'll wrap them later in black header wrap. All I lack now is oil and gas to at least start it. I finished all the engine wiring, ran the throttle and choke cables, and got 4 chains made last week. I had to order more chain and two idler sprockets -which showed up wrong- so that will be another day. If I can at least start it up and get it to move under its own power, then I can take it all down to paint it. I've already gone around it and filled a bunch of holes (like the PO's unnecessary amp meter hole in the tub) with the plastic from the exhaust hole I cut. Man, what a long and stanky process that is. I'm going to just epoxy the rest of 'em.
  2. #22
    5,055
    That exhaust looks nice, I would put some type of heat shield where it is near plastic now before it distorts it. Keep the shield off both the mufflers and the plastic.
  3. #23
    Texas
    2,174
    Maybe make a shroud (metal box around a metal box) to go around your mufflers to keep the heat off the plastic. Really looks like a fine project.
    I've got a similar muffler on a utv, and it really works great, lots of snarl when you get on the throttle but not too loud when just under normal load. I like the way the headers look as well, and I bet that H.F. motor really sings.
  4. #24
    Mar 2010
    Oconee County, SC
    823
    Looks good. One thing I would suggest beyond wrapping the exhaust is to apply reflective insulation to the inside of the tube. I also wrapped the underside of the rear seat and engine deck. Added fan to force fresh air into engine compartment and a cutout to allow hot air to escape above the exhaust. Hustlers are notorious for overheating and vapor locking on extremely hot southern summers.
  5. #25
    Feb 2016
    Mississippi
    1,108
    Hey Sean, what's going on with your build. You were moving like wildfire there for a while.
  6. #26
    Jul 2015
    Cameron / Lockhart, Texas
    62
    Quote Originally Posted by SeanD View Post
    Anyhow...
    I have a HF pipe bender and it works great, but I learned a trick for a friend that builds funny car drag racers. You can't just put pipe in a bender and have at it. You have to fill the pipe with something in-compressible and cap the ends, or the pipe just collapses. He uses sand. Cover one end with several layers of duct tape, fill pipe with sand, tapping it on the ground repeatedly so the sand packs in real good, then once you have the sand overflowing the other end of the pipe a bit, cap that end with more duct tape then it'll bend smooth as silk.
  7. #27
    May 2016
    Buford, GA
    72
    it's been six months?!?! Man! Well... what had happened wuzz... I got to the point of building the body band around the -um- body, and I had gotten a couple old trailer hitches off customers' trucks that had been replaced after accidents, which I was going to incorporate into the body band-bumper assembly. BUT, one of them was square tubing and one was round tubing, which I didn't like. So, in waiting for another square tubing hitch to show up in the shop's metal pile I sold the last bike I had built, which then left me with NO PROJECT. So I bought another old bike and built it into a bagger...
    Once it was done with a For Sale sign on it, I had gotten a second square tubing hitch, some angle iron, and went at it. Back on track! It also helped that I finally moved my "shop" setup into the big building behind our house and out of the basement garage. So I did the pie cut thing to get the 1/8" angle iron bent around the corners (the second corner was better than the first for sure), but didn't know what everyone else was doing as far as one piece, two, four pieces, whatever, and how to join the pieces of the band. I came up with this- a joint right next to the engine on both sides. That gives me one front and sides piece, and one rear piece. With the reciever hitches they are heavy and need more support than just the small bolts through plastic. This joint lets me pull the pieces in tight with the body. And yes, I will grind those two pieces flush with one another...
    After the hitches were on, I went and drove it around the yard, only to see that they were way too floppy, especially with a winch stuck in the front (into a hitch). So I made up from more 1/8" angle iron these angry looking braces that double as skid bars on both ends. Now the whole bumper band assembly is RIGID.
    After I got to this point and was satisfied with all the fitment I started to take the WHOLE THING back apart so that I can paint it, rebuild the T20, and put it all back together again. By the end of today it should be completely blown apart again, and I can send all the metal parts off for bedliner while I fill holes in the body. yay.
  8. #28
    Sep 2012
    Hanover,PA
    1,012
    LOOKS GOOD !
  9. #29
    Texas
    2,174
    That looks sharp. I really like the Vertical bracing. Nice and heavy duty.
  10. #30
    2,674
    busco beach is a very large atv park outside goldsboro, n.c. twice a year ( oct. and april ) a large group of aatv enthusiasts gather for 3 or 4 days of trail riding. with good rains there is lot's of muddy holes and trails. there are numerous lakes, some to ride in, and camping or rv sites. it's a super time with lot's of great people. some come from the ga. area. check out the videos on this site and see what it's all about. johnboy va.
