T-20 Bearing failure symptom?
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: T-20 Bearing failure symptom?
  1. #21
    Dec 2009
    Long Island, New York
    99
    Quote Originally Posted by Robinhood02 View Post
    great to hear you had the problem nailed all along, wow that brg went quick, good to know for future
    I actually thought it was the output bearing. I never considered the input bearing until thejunkman posted that possibility. George figured it out right away after we cracked the case. Thanks to all. You too Charlie. BTW, I picked up two cans of that Comet spray lube from manufacturer's supply. It's not cheap, but I figured I'd grab two while I had the opportunity. Question, where exactly should I spray it on the primary and secondary (other than the main shaft)?
  2. #22
    Aug 2008
    High Level ,AB , Canada
    369
    i keep the slider surfaces clean and lightly lubed, as-well-as the internal components of the primary (through the vent holes in the ramp cover)
    He who has not cruised the back country in a 6x6 , has not lived life to it's fullest
    A Mans level of mechanical education directly corresponds to the level pain suffered while getting it
