New hustler project - bucket of bolts
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 34
Thread: New hustler project - bucket of bolts
  1. #21
    May 2016
    Buford, GA
    72
    It's so nice and bright in your garage.
    So with the tensioners- what happens to the original tensioners that is bad? I just have zero experience with thrashing on a Hustler. Do they just twist and go out of adjustment or what? I need to fix whatever the problem is now, not after paint!
  2. #22
    Feb 2016
    Mississippi
    1,108
    I don't have any experience with them, as this is a first for me. The originals look weak in that they rely on that little threaded plate to hold them in place. My C channels were bent so I could tell they had problems in the past.
  3. #23
    Feb 2016
    Mississippi
    1,108
    20160718_205122[1].jpg20160718_211332[1].jpgSlowly but surely making progress. Got the frame and axles in along with 5 of the 6 chains. Set the engine in last night and breathed a sigh of relief when it fit. I was afraid it would hit the back of the tub but I have about an inch of clearance. Still haven't made a decision on tires/wheels. Have to get key switch, amp gauge, build wiring harness, get choke and throttle cables....all I lack is finishing!
  4. #24
    Sep 2013
    Caldwell, Idaho
    1,175
    Looking sharp
    ST400R ATTEX(Smiley)
    500 Super Chief
  5. #25
    Feb 2016
    Mississippi
    1,108
    Still slowly making progress, but here's what I've done since the last post:
    Fabbed up a front bumper
    Built wiring harness (new key switch, amp gauge, all wires and connections, rectifier)
    Got headlight covers polished up and reinstalled
    Rims sandblasted and painted
    Got some Rawhide III's to go on it
    In the process of fabbing the floor pans and exhaust system. I'm going to add a partial body band that will wrap around the front. I'm adding a winch and I will feel better if it is anchored to the bumper and body band, since it all plastic.
  6. #26
    Feb 2016
    Mississippi
    1,108
    Got the rawhides mounted (it took 30+ psi to seat them) and made me a tire caliper to get each tire's diameter just right.
    Getting pretty close to riding.
    I had some carpet left over from a pontoon boat project..... I may be the only goober with carpeted floorpans in a machine that lives in the mud.
  7. #27
    Feb 2016
    Mississippi
    1,108
    Finally finished!!!! Its been a slow process but this thing will boogie!! Here's some shots of the finished product.
    Had a little debacle with the fuel tank, but thanks to ArgoJim it's all good.
    To recap, this machine has:
    New transmission bearings, seals and thrust washers
    New drive clutch and belt
    New engine mounting plate and vibration isolators
    12 new wheel bearings
    New Rawhide III's
    New wiring harness, new key switch, new amp gauge, new solenoid, new battery
    New fuel line, shutoff valve, filter
    New bumper and partial body band
    New winch
    33 feet of new chain
    6 new chain tension idlers
    New throttle and choke cables
    New floorboards with luxurious carpet
    New padded front seat bottom and back
    Powered by a twin opposed cylinder 20 horse Briggs.
    Now, when I get my 4 wheeler fixed, me and my boy are going down the road to the Sardis Lake recreational area for a ride!! I'm sure I'll have some fine tuning to do after a good ride.
  8. #28
    Texas
    2,174
    Sardis Lake, now your talking my language for some crappie fishing / feast, as well as a ride in a nicely restored Hustler.
  9. #29
    5,055
    She turned out nice, after a ride or 2 you could rejuvenate the upper body with a heat gun to loose the chalky fade. I'd take it easy on any ditches until you find the angle that exhaust may hit. Great job on the seat.
  10. #30
    Nice work! You should have a machine now that will give you lots of trouble free riding. Have fun with it.
