red spring on a t20 clutch
Results 11 to 20 of 28
Thread: red spring on a t20 clutch
    Nov 2008
    mo
    164
    pull out the tranny , remove the clutch, I soaked mine with wd for a few days and it came right off then take apart the clutch (it all comes apart after you remove it from the shaft) watch out for the little key thing , slide out the old spring,push on it a few times and say wow thats weak compaired to the new one, put in the new one , slap it back together and walla...hope that helps
    Almost sounds too easy. The old clutch comes off pretty easy. Sounds like the 2nd step is even easier.
    Dec 2007
    eden nc
    1,484
    Quote Originally Posted by kestianj View Post
    this thread is uless with out pictures
    I'll try filming it and put it on Vimeo...with copyrighted rock and roll playing on it.
    Nov 2008
    mo
    164
    Quote Originally Posted by rdr View Post
    sorry I didnt take any, but its really easy ,like a 30 min job
  6. #16
    Nov 2007
    1,059
    Kestian, I really wish I could give you an answer based in factual evidence. But I didn't realize how much the incorrect throttle cable setting affected the overall performance of my machine until after I had changed both the cable and sprockets. Bummer! I do however know that it greatly increased my log dragging ability and crawling up short steep banks is also easier, I can go up stuff at about half the rpms that I used to have trouble with.
    I can also tell you that I had to add to the length of the chains, I needed a half-link but have heard of other members having problems with chain breakage when using them. On the right side I only had to add 1 link, but the left side needed 2 links 2 links was actually way more than actually needed but 1 was about a link pin width too short. After I ran it this way for a while I managed to get down to only 1 link, but it's really tight, and I will go back to the longer until it stretches some more. I think that Boncrshr had this same problem. I toyed with the idea of shimming the tranny up some, but then I would have to change the shift linkage ... One thing I have learned about these machines; (and it may just be me) everything you change- changes something else and that changes something and ...
    Gregg
  7. #17
    Aug 2007
    near olean, ny
    1,083
    Smile experience..
    Try rebuilding , fixing, etc over 400 ? some machines, of all different kinds too, over a 30+ year period,, you learn much, knolledge replaces fear,, one learns alot.....
    The accumlative knollege of this sight is very fascinating, you can learn much on this site, what fits, what doesn't, where to get pieces, parts, the best deal on where to buy, even obsolete parts to repair or replace what ever you have... from gip seas to maxll's and how to fix almost everything too.
  8. #18
    Aug 2007
    Texas
    582
    brushcutter, is that 40 tooth worth all the work?
    YES!!!! That is the biggest bang for the buck modification I have done....it turns your Hustler into a tractor!!
  9. #19
    Nov 2014
    Finger Lakes NY
    12
    where do you buy the red spring? thanks
  10. #20
    Mar 2015
    Quad Cities
    54
    Quote Originally Posted by Zip6x6 View Post
    I too would like to know. I see Richards relics has them but have read to stay away.
