My throttle cable froze while I was riding and I got home fine. I thought it was the handle but it just came off but found it was actually the throttle cable but the main question is, is a heated throttle cable needed or not heated.
heated throttle cable or not heated
If you operate in below freezing temps very often I would put a heated cable in. By blowing out the water and flushing with isopropyl alchol will prevent freezing. I got by this way for years before heated cables were available. The water gets in the cable from running down the lever. If you cover the lever with a tin can when sitting it really helps keep it dry.
I too use the antifreeze in both cables. I use a snowmobile primer bulb clamped to the cable. Once I suck a enough fluid in it, I put pressure to it with an air gun. A few times on both cables and I'm running it in below 0 conditions with no issues.l like to buy stuff and no I don't do payments!
I have a IV with a heated cable. It only froze a few times when the machine sat there, engine off, for long periods of time. Once the engine was running the cable warmed up fine.
I used a small syringe with a built-in "needle" to squirt thin oil into the cable.Stand for the Flag. Kneel for the Cross.
