it will create a pressure drop at a specific flow rate. reduced flow but will still probably flood at idle. you could loop the fuel line back to the fuel pump inlet through a tee at the carb but you should add a a valve to atmosphere in the return loop to vent the air out of the line to make sure the the line is full. air in the line will probably give the pump fits..
