thanks dirt, no rush..... johnboy va.
Johnnyboy my rims are 12x10 with the 5 x 4.5 bolt pattern. On the distance from the center mounting surface (where the hub meet the rim) to the very outer edge of the lip is 5 3/4 inches. When I get to the office tomorrow I'll scan an illustration and post it.
Johnnyboy here are more details.
rim dimensions.pdf
thanks buddy, but for some reason i can't pull up the illustration. is the 5 3/4'' measurement to the front of the rim ( if your facing the wheel ) ? i need the measurement to the rim edge if your facing the back of the wheel . thanks , j.b.
rim dimensions (1).jpgThe measurement is on the inside of the rim, or the tub side. Try this image.
that's it. thanks a bunch. i wanted to see if the rim and tire would clear my front drive chain. my chains are outside the tub. j.s.
The tires appear to be Kenda Bear Claws. I have a set that I got with an amphib, but the tires are not swimmers, at all. They do perform well in the mud, and I transferred the tires to a four wheeler and have two backups.
A Hustler 980 tall tub is a good find. Congrats on that. The old Kohler 18hps were very much under rated, I always thought they had the power and torque of a 23hp engine. The Kohler will tune well too.
They are GBC Gators. 26x12x12. The deep lug looks like they should swim pretty good, but only time will tell.The tires appear to be Kenda Bear Claws
So I still haven't touched my new to me machine, but look what I ran across yesterday. I think the this would be a good modification for the 980.
