Amphicat trans, what is it ?
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Amphicat trans, what is it ?
    Just to finish this matter up. Amphiman1 said the Amphicat has a Borg Warner Box and it seems to be a good one. Previous owner showed me how it grinds badly when you push sticks and hold down reverse loop. Nothing was wrong with mine, Amphiman1, "leve sticks alone, hold down reverse loop and gas it, works fine. I just hope the preveious nimrod owner didn't do too much damage grinding on reverse. Thanks to all for the input.
    NEXT UP. I have a Yamaha 2hp outbourd to mount on her.
    Lets make some real tracks in the old pond.
    Aug 2007
    near olean, ny
    1,083
    Exclamation amphicat trans...
    Hi, step on the "loop" then give it some throttle.. more pressure on loop may be necessary,,,,sticks in neutral.. backwards yoiu go, If the trans is adjusted properly, you can steer it in reverse too...
    Your friendly neighborhood Amphiman1
