Hustler 23HP T-20 issues
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Hustler 23HP T-20 issues
    Apr 2019
    Bismarck, ND
    16
    It looks to me like the center plate is worn on the ends. Newer models have a slot in the ends for thrust washer tang. This stops the thrust washers from spinning and wearing the center plate. Be advised that all the bushings are not sized. Once pressed in they have to be fit. With the wear I see on your ring gear drums they should polish up well and not be very far under specs. The band surfaces in video is easily polished. 200 RPM in a lathe with 100 grit paper gives nice dull finish. You don’t want mirror finish where bands run. I can get you the dimensions of center support if you want. Text me at 907-388-8582.
    I'll text you tomorrow, I was looking around and found the end plate picture http://www.6x6world.com/images/t20-s...ainer-ring.jpg, My end plate doesn't have a tang left, that may be where some of the end play is. So I might have to add an extra thrust washer and cut a notch in the end plate, or get another end plate.
    Apr 2019
    Bismarck, ND
    16
    Quote Originally Posted by gfleharty View Post
    I talked to Matt at Mudd-OX yesterday, he gave me some more background on the Skid-Steer transmission. There have been numerous manufacturers of this transmissions over the last 40 years, and many design changes. Including the tang type washers were not used on every transmission because the center plates were made differently. He said that the master rebuild kit includes all the standard thrust washers. I will update the thread when I get the kit and start putting it together.
