Slow progress. Have all the parts to put the transmission back together except the bands. They should be back this week from Transmission Crafters. I have milled, drilled and tapped the case halves to pin the U channels.
I'm also the process of making a second shifter for the split shift modification. I like the positive stops of a hustler shifter so I'm duplicating that design and will just add to the existing shift lever.20190616_073831[1].jpg 20190616_073820[1].jpg
I don't like this sprocket. Some teeth are worn short, somehow, and others are bent just a bit.20190616_073749[1].jpg
I'll order a machinable sprocket and cut this one off the tube.
