Hustler belt
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Hustler belt
    Nice video dirtdobber. My belt acted similarly as yours. It didn't spin at start up, only after I started giving it gas to watch the clutches work. It stops with little residence. It was running in the pic with my hand on the belt, wanted to get the part # in the pic but the belt would slowly turn and stop with the # out of view. Just loaded it on the trailer with no shifting issues and it'll actually crawl at idle with the sticks forward . Seems to have more low end than before
    Belt update. Drove it a couple miles in the marsh. The belt did squeal but only on hard turns at low rpms, when I gave it gas over 1500 rpms or so the squealing would stop. No issues going straight, only low rpm hard turns. No shifting issues and my top end improved significantly when I finally got back on dry land. My question is should I shim the rear motor mounts up to tilt the engine forward a little to put more slack in the belt or just let it wear in more and see how it go's. My old belt only had about 10 hours on it so wasn't worn, this one's 7/16" shorter.
    Feb 2016
    Mississippi
    1,108
    The belt could have been slipping due to the torque required for turns. Take a piece of course sandpaper and scuff the sheaves of both pulleys. Sand in a radial direction. This might solve your problem.
    Apr 2019
    Bismarck, ND
    16
    Hopefully it will work fine. The thing you want is the belt to be just tight enough that it tries to spin the driven clutch. If its too tight and constantly spins the driven clutch then you will grind the gears every time you change F-N-R. It may also cause your belt to overheat.
    This video is how my machine is set up. Although the driven spins at idle it stops with just a little resistance. I have no problems shifting or belt squealing.
    https://www.youtube.com/watch?v=dmkUjcR-opE
    That is an awesome video, I am setting up a 23HP vanguard and wanted to see how it should look. Quality Drive Systems helped me with my belt selection.
  5. #15
    Feb 2016
    Mississippi
    1,108
    I'm glad it was helpful. Good luck with your setup.
