T20 Input Shaft - what steel is it made of?
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: T20 Input Shaft - what steel is it made of?
    Oct 2009
    Monroeton, Pa
    284
    I think jerseybigfoot?s spacer idea and msafi65?s heavy washer fix together with blue lock tight should fix your problem. I would also make sure the belt alignment is such that it is not putting outward pressure on the secondary. Let us know how you make out, a frustrating problem for sure.
    Aug 2011
    Kotzebue, Alaska
    1,209
    Yes, a thick washer is a good idea. It never occured to me the washer could be an issue.
    I
    Regarding new input shafts, I can't find any for sale. Got any ideas?
    Dec 2008
    Eastern PA
    262
    I think your best bet is to post something in the wanted section. They are available from Route 6x6, but I think you will be surprised by the price.
    Aug 2011
    Kotzebue, Alaska
    1,209
    Thanks. I did check at Route6x6, they have used ones only right now.
  5. #15
    Aug 2011
    Kotzebue, Alaska
    1,209
    I make a clutch washer on the lathe that is about 3/8 thick with 7/8 shoulder to center. If the shaft has had the clutch loose and is worn down below .874? at the extreme outer end the clutch won?t stay on. I?ve set several that owners didn?t want to replace the input shaft with gap filling lock tite and have had a couple run for several years. I don?t recommend it. A new shaft and clutch have about .001? clearance.
    Do you have this thicker washer you make available for sale? I'd like one, with thr proper bolt as well. ?(Our hardware store doesn't carry the proper bolts, I have to cut long ones a bit shorter.)
    Thanks.
