Have you heard of the planar heaters in pelican case? It burns a bit of diesel it’s adjustable for heat out put and runs off of your 12volt plug in. You can use it to heat a tent as well. I’m in Alaska and have considered putting one of these in. https://www.youtube.com/watch?v=jvRf...&feature=share
I have a 2020 Aurora 950. I put one of those Chinese diesel heaters in mine. I took out the back seat for the winter. The heat will blow you out of there. Works great
I installed one of those Chinese diesel heaters in my Aurora. Keeps it nice and warm when there is no sun to heat up the cab. Easy install. No issues with smell. I keep a carbon monoxide detector in there as well.
We went ice fishing for the day.
Started at -13F and climbed from there to about 10F.
No heater, but plenty warm.
Turn into the sun and it is like it has a heater with the black top.
anyone use a espar or webasto? i would asssume the diesel version would be safer considering the offroad environment these vehicles are subjected to, although the diesel version would require the addition of a small aux diesel tank. i think the 2kw version would provide ample heat to a cabbed argo.
