Well after quite some time I have finally been able to run this vehicle, is quite fun although have a few questions regarding the vanguard 16HP
1st has to do with the governor and how to set it up properly, or remove it intirely, so what have all you guys done
2nd have any of you had problems with the beads on tires that are unable to seat and also bend so it cannot even keep in 10-15psi without popping off the rim
3rd I have not run it much yet although it does seem to run hot, all the vents are clear and the original cover is in place which has lots of openings
Any help will be appreciated
Sparky
