ok fellas. anyone have any numbers or sources for the oil and air filters for these engines?? I've had no luck whatsoever at finding anything!
Thank you
Dave
Thank you
Dave
No one has changed an oil filter on these 22 hp predators yet???
LOLOL
I would think it would be the same as a Briggs or Kohler filter.
Those are Origonaly based off of a Honda Car filter as I remember.
Just check the threads and seal ring to make sure !
What is your Spec's ? ( Size ) I can cross them at work if you like ?
Also would you have a # off the old ones ? I can work off that also.
Just go off of the same cc +- 20cc Honda, they are copies and should be the same. Bring them down to the local mower or parts store for comparison.
Thanks guys. Will try to get one today for a honda and go from there
I looked it up once and its the same as Honda GX670.
Every Chinese, Taiwanese, or Indian made oil or air filter I've ever needed I've sourced at Oreilly's Auto.
