Hello,
I have discovered when driving my Max II that performance is better when cornering (especially in thick mud) that if I push forward on the stick that would normally be in 'rest position'.
Is this normal or is adjustment needed?
Also noticed when I took the top off the Max that when I move the sticks, the valves (I don't exactly know what they are, but they look like valves) take a bit of time or jostling to move, after the stick has moved. Does this need lubricating or is it because the engine is not running? If they do need lubricating, do they need anything special or just WD40/grease?
Not sure whether the two problems are related...
