Questions
Results 1 to 10 of 13
Thread: Questions
    Questions
    Finally got it running sort of seems to only like full throttle and sticks full forward. Engine runs ok at all rpm ranges , was hoping it would like driving slow but it doesn't
    Feb 2016
    Mississippi
    1,108
    What kind of machine, engine and clutch setup do you have?
    Old chaparral with jlo 340, clutch unknown . If i give it 1/4 throttle and push sticks forward it goes a couple of feet and stops. If i give it 3/4 throttle and move sticks slowly foward it does the same . Full throttle and push sticks foward fast and it jumps up and moves about 25 mph .
    Thinking belt or clutch , hoping to rule out transmission
    It does sound like a belt issue. Have you checked the belt tension or the condition of the belt to make sure it's not loose or worn?
    Belt seems loose to me i could pull it up and take it off transmission pull simply by turning the pulley don't see any way to adjust it. Not sure how tight belt should be . So guess I will be ordering a few new belts
    I'm not familiar with the drivetrain of a Chaparrel. Check to see if your engine mount allows you to slide it back. If not, perhaps you will have to just buy a new belt. Hopefully one of the other members more familiar with your machine can give you some better advice.
    5,055
    A 2 stroke clutch may have an engagement of as high as 3500rpm, you will need some room to test a 2 stroke machine.
    Probably not going to be able to ride around 5 mph.
    Mike definitely need new belt ,from researching other post i can figure out width but no simple way to figure length. Engine has zero adjustability so belt has to be right on
    Argo Jim, i understand 2 cycle engines need to rev but a steady 5-10 would be nice is this possible?
