Hello.Does anyone know size and or the part number or a cross reference part number for a 70 300D Drive Belt? It has a Baker Hill transmission. My machine came with a belt that was slightly wider than it should be. I want to switch back to factory specs.
Attex part #297-21-005. Gates 6040. I'll posted the chart I found in the gallery. It has the same as my 208tt I see. Mine is a dayco ???? I will try and look at the number tomarrow for you if it would be of some help.
My belt is a dayco max 1106. It isnt right though, I checked and is should be 1-15/64th wide and 43-5/16. Mine isnt that wide and wont work if it was. Must be a worn out sled belt or something???
If you no the size of the belt you need you could try EBM mill & elevator supply. on there home page just click the table of contents scroll down till you see the varible speed cog- belt then they have a chart they are dayco belts. We ended up getting ours from there for our 400 chief . Gates are really hard to find the correct one. Hope that helps.
I actually measured an old belt once and used the measurements to find an alternate. It worked out well. Measure the width and circumference on the old belt. Eyeball the additional width if the belt appears worn.
I think I might have an old belt chart saved from the now defunct "Central Snowmobile.com" I'll post it if I find it.
