Originally Posted by
Robinhood02
the best trani system i've ever seen for this kind of app. is the drive unit out of an old mechanical drive agricultural swather from the 50s 60s or 70s ,they all had only one gear and it was forward ,if you wanted to go right ,pull back a little on the right stick ,if you wanted to go back you simply pulled back on both steering handles ,if you wanted zero turn radious pull hard back on one stik and you will have one wheel going forward and the other backwards,,, the beauty of it is it worked going back too if you were going backwards you could do zero turn as well and it is so simple these things ran for decades with little or no repairs not to mention it was the drive unit on a 3500 lb unit not a 805 lb Max, LOL and i think it weighs less that a T20
