Another max 4 rebuild
+ Reply to Thread
Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 54
Thread: Another max 4 rebuild
  1. #41
    Join Date
    Feb 2019
    Location
    Partlow va
    Posts
    34
    20191025_163214.jpg20191025_163249.jpgSoo. I opened the t20 transmission just to do a once over and to replace bearings and seals as needed. I came across as an issue with a lower mount bolt stud cracked on the inside. I went to investigate and unfortunately the casting over the stud broke off. How concerned should I be about this? What are your suggestion? Thanks
  2. #42
    Join Date
    Feb 2019
    Location
    Partlow va
    Posts
    34
    20191026_153205.jpg20191026_153224.jpgOk so newest load of fun with with transmission is the center plate. I didn't see it until reassembly go figure. There is damage to the area where the thrust washer goes. It seems it wore away pretty good when compared to the other side. Not sure why or how this happened. Can this be fixed short of buying a new plate or is that the only option. Also what could I do to prevent this in the future if anything at all. Thanks again
  3. #43
    Join Date
    Jun 2007
    Location
    Central NJ
    Posts
    1,470
    It looks like it may have been assembled without a thrust washer . You may get buy with a just a new thrust washer. If you want to adjust the clearance and salvage the center plate there are shims available from McMaster Carr. Its amazing what a T20 will tolerate.
    Acta non verba
  4. #44
    Join Date
    Feb 2019
    Location
    Partlow va
    Posts
    34
    Quote Originally Posted by jerseybigfoot View Post
    I can deal with shimming it. it looks as though the gear was chewing away at it but the gear looks fine as best I can tell. what would your do with the situation with the case bolt? Im un decided as to what I wan to do with that.
  5. #45
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    Nmmichris, I have a parts transmission if you would like to buy a center plate and case half. If you're interested, I'll post some pics so you can see what I have. Which half do you need - belt side or other side? Is yours a popsicle or U channel style?
  6. #46
    Join Date
    Feb 2019
    Location
    Partlow va
    Posts
    34
    It's the right side case half. It has the U channel style. I'll have to check out that drum that was on the damaged side and make sure that lining isn't destroyed. And verify the sun gear. I hope this is the end of the major issues with this. Really want to get this running
  7. #47
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    Ok. I'll get some pics of my right hand case half.
  8. #48
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    Here's some pics of the case. Note that the RH side of this transmission shows the input shaft. This is actually put together backwards as I just threw it together to keep up with all the parts. I also want to point out that the plunger holes have been sleeved. I don't know if it was original or a repair of some type. I have never run this transmission. Also, I have drilled and tapped this case half to pin the U channel.
    PM me and we will workout the details.
    20191027_131103[1].jpg20191027_131024[1].jpg20191027_131046[1].jpg20191027_131146[1].jpg
  9. #49
    Join Date
    Feb 2019
    Location
    Partlow va
    Posts
    34
    hows the center plate look?
  10. #50
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    I sent you a PM.
+ Reply to Thread
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
